iPhone 5 will not boot.. constant bong noise on charge..
I have an iphone 5, and in the beginning i had an issue with the battery percentage being at 20 and the phone shutting off randomly. however when i plugged it back in it would charge
So i was away the weekend and this happened again and when I tried to charge it up to turn it on again this time it would not power up or find the cable.
So I thought ok as I could still see a lightning bolt cable on the phone showing i need to plug it in, I thought it was just the battery and dock port that went bad.. So i took it apart and ive put in a new battery and put in a new dock port..
Now the screen will not turn on and there is a constant beeping noise when in charge or a vibrate if i switch the slider.. (like the plug in charge noise, bong)
I dont know if i need to put a new screen onto it now.. Hopefully someone can help advise me..
Its weird cause I can see in itunes the phone is connected and is charging now.. but when i try boot the phone up when its not connected to a lighting power cable and when there is no screen attached it will not boot..
I wanted to see if i could hear noises cause i thought i might be able to determine it was the LCD in that case..
Does anyone know if you can boot the phone the up with the screen on it ? as in be able to hear noises etc.
Ive tried the hard resets etc. and even a different power flex cable..
does anyone know about the constant bong noise while on charge???
Es esta una buena pregunta?
