The HTC EVO is a Smartphone by HTC powered by a 1-GHz Snapdragon processor and runs the Android operating system.
Preguntas 92 Ver todo
My phone overheated and won't turn on, what do I do?
I left my phone outside in my car by accedent, now it is warm and won't turn on, what do I do? I think it overheated.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 6
Comentarios:
Hi there~ I had a similar issue, when I woke up the phone was suddenly overheated and i couldn't remove the battery as in was inbuilt. I was really worried and scarred to put it on charge cause it my blast or something. then i was looking through the internet to help me and i found the answer.
For inbuilt battery phones, you just need to press the power button and the volume(-) button at the same time for like ten to fifteen seconds... and viola the phone will restart. Also for some phones the volume (+) button might also do the trick. This solved my problem , i don't know why my phone over heated so I'm also gonna take it to the repair store just to make sure there is nothing wrong with it.
All i can say is god bless GOOGLE \(^.^)/
por
I had the same problem earlier and press the power and volume (-) button too. It works!
por
Agregar un comentario
12 Respuestas
Solución Elegida
Sage Jurado, remove your battery and check on it. See if it shows any deformity. It is very unlikely that you damaged the logic board, most likely it is the battery that failed. I'd suggest that you replace the battery and re-evaluate from there. Hope this helps, good luck.
Fue útil esta respuesta?
Calificación 7
Comentarios:
what if its an iremoveable bettery
por
i cant rove it i have the sNMSUNG GALLAXY 6S EDGE
por
Esta respuesta fue originalmente para otra pregunta .
Try letting it cool down. Then try turning it on in several hours.
Calificación 4
I put it in my backpack for 5 minutes and when i went to take it out it was super hot and wouldn't turn on . What do I do??
Calificación 4
Remove the battery and check to see if it is deformed this can cause it to fail. if it is the battery replace and then evaluate from there.
Calificación 2
Comentarios:
Cant access battery to remove it ...phone is Nokia Lumia 1320
por
Will it explode ? Please let me know ...im scared
por
when I turned it on its shows a notification.. that you phone is over heating now and its doesn't works properly
samsung glaxy j7 device
please help me
por
i have the smamasung gallaxy 6s egdge and my phone got over heart my phone was lay buy me and i wasnt on it my friend sna me went to look at it i read it and took it with me to the bathroom than all of a sudden it get real over heated and shut off so i left it along for a little and try to trun it on it wonuldnt so the hole at the button is to restard i prsh thaat and nothing and than put it on the charge the like z thang came on n nothing so i unplug it......let me know im kinda scarefd
por
por
Mostrar 1 comentario más
This happened to me this afternoon, my phone is in my bag and then my friend called, when i hold the phone it is hot then suddenly turned off/black background then i press the lock button for a long time but nothing happened, i hard reset it then it turned on. I read an article about the phone will turned off when overheated to avoid accidents.
Calificación 1
Comentarios:
That good to know.i was trying to find a answer to my son phone and found one to mine.mine goes black I have to restart it.never new it was probably keeping it from getting too hot.but my son has the Kyocera .and I can't turn it on . battery doesn't come out.and when I try to charge it the top of it gets hot,? Didn't it burn up? And have to buy another phone? Less than 6 months old
por
I got a phone like the one I have in Winston Salem, when I try to charge​ it,it GOT HOT.Verizon replaced the first one-no charge, Sent it back to Ft.Worth,,Texas and I received a new phone and it's doing the same thing.A message popped up on my phone telling me that they gave me the WRONG CHARGER FOR THIS PHONE,Now it's doing the same thing-GETTING TOO HOT when it's being charged.
por
I also have the same problem. Please send me how solve that problem. nilani.samaranayake@yahoo.com
por
Please be advised that myself, nor this web page can be held responsible for damage to any device, should an attempt at repairing one's own device fail. Always make sure to consider hiring a professional repair shop to fix your device for you.
Diagnostic steps for not charging:
1) Check for a blocked port (Lint build up can keep a cord from fitting in properly. if the frame of the plug is not flush with the device, using small tweezers, and being careful not to damage pins, pry out any dust or lint.
1) Try a Known Functional Cord. (Works on another device)
2) Excite the battery: Hit the + and - of the battery with an external power supply for approximately 10 minutes. (Be sure to verify you are using the amperage and voltage that the battery can handle. (Located on the battery with the specs.)
If the device boots, then the battery is functional, and you can continue forward with your diagnostics.
3) Scan board, and Flex circuits for physical damage. Looking for signs of blown or chipped components. Scorch marks, or corners of components broken off. Replace as needed, and test again. A 10X+ microscope assists very well in this stage
4) at this point, plug in the device again, and check if it charges. if it isn't, then go forward with replacing the charge port itself.
5) if replacing the charge port does not fix the issue, then you are experiencing an IC or board failure, in which case, it will just be better to replace the device.
---I hope this guide has helped you in your diagnosis.
Calificación 1
Comentarios:
2) Excite the battery: Hit the + and - of the battery with an external power supply for approximately 10 minutes. (Be sure to verify you are using the amperage and voltage that the battery can handle. (Located on the battery with the specs.) This isnt a very good idea. and most people do not have the proper tools to do this. I wouldn't suggest it.
por
Isn't that what you do when you are plugging in the charger to charge it. :)
por
when you plug it in with the charger, it goes through the charging circuit, which needs a relay to tell it as to whether or not there is a battery plugged into the device.
if it does not get a minimum voltage or 3.1V, the battery will not be recognized, and it wont charge. my process of "Exciting" the battery, raises the base voltage of the battery, allowing the circuit to recognize it.
por
I have also a problem with my asus zenfone, No power when i tried to power on, Cannot Charge; being overheat immediately in a charging part of the phone. I used to unplug the Battery and the result is still overheating immediately when being charged.
Please Help me,
Kindly send me an email @ romeodelrosario0011@gmail.com
Thank you very much...
Calificación 0
Comentarios:
I do have a same problem with my asus. :(
por
Tengo el mismo problema amigo, si llega a encontrar una solución por favor escríbame a mi correo electrónico djhamiltonm@gmail.com
Muchas gracias
por
Phone is dimmer than before * # Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. **)
Calificación 0
Say hi to it and that will work
Calificación 0
Comentarios:
Hey that worked thank you ,. Now will you have my children please? I think I love you.
por
uhhhhhhhmmmmmmmmm, that's fricking weird >~<
por
any way, My phone is an Android verizon , and I would be playing my game then the screen goes black, when I turn it off I try and turn it on again and the screen lights up but I cant do any thing. it has happened to me before, but it oly took about 3 or 4 hours to turn on again, Now its takin about 8 hours. What do I do?
por
Did u try to change the
Calificación 0
Comentarios:
BATTERY Sorry FOr Mistake
por
my phone was on under my pillow. and morning came , my phone was hot and cant turning on. what should i do?
Calificación 0
I put it in my phone on my under pillow for 6 hours i think and when i went to take it out it was super hot and wouldn't turn on . What do I do??
Calificación 0
Añadir tu respuesta
Sage Jurado estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 17
Últimos 7 Días: 165
Últimos 30 Días: 872
Todo El Tiempo: 14,906
