Saltar al contenido principal
The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
Preguntas 149 Ver todo
HTC ONE M7 HTL22 (Japan variant)
Hello,
I have a HTC One from Japan, also known as HTL22, it has a back cover that is easy to remove with a sliding button. After it, it is possible to see some screws, but not the electronic circuit yet. I would like to know if it is necessary to remove these screws or to follow a similar procedure as described at iFixit to disassemble the phone?
I would like to do it, because I want to change the camera module as my phone has a "purple" problem.
Thanks.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
7 Respuestas
It's never bad to remove the screws at first. Because all the screws in the phone are to fix some components.
Fue útil esta respuesta?
Puntuación 0
Screws are easy to remove and replace, as long as you keep track of them. Try removing all the screws you can find, including the ones under stickers, noting their locations. See if you can pry the phone open, hopefully it has a midframe you can remove, something like this guide. Under the midframe you should be able to find the motherboard and possibly LCD connectors/display connectors. Give that a good try before you try to open the phone by the display, that can be dangerous and very difficult!
Puntuación 0
somebody know if lcd that fits to 801e will fit to htl22 too?
i see that the mid frame are identical and didn't find any lcd for htl22 on ebay,aliexpress.
Puntuación 0
hi how can i buy a cover for my htc m7 htl 22 2014 modle
Puntuación 0
hi how can i buy a back cover for my htc m7 htl 22 phone
Puntuación 0
Hi, Where can i buy full housing cover for my HTL22
Puntuación 0
I was wondering if the power button flex would be the same as the Canadian model?>
Puntuación 0
Añadir tu respuesta
Tiago estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,505
