Quad-core 10.1" Android tablet with docking keyboard.
Preguntas 41 Ver todo
I can't charge my tablet
Hi there,
I can't charge my tablet and I think it's something to do with the actual tablet, not the charger. I have tried a different charger and still nothing.
The only way I saw my tablet was charging when I have connected it to my laptop with USB, but it was really really slow and I have to just leave it. If I will be using the tablet while charging with a laptop the battery % goes down. Also, it is not showing me that Android "storm" icon when it's charging it.
Not sure what to do with that. Any ideas?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
Visita Nuestra Tienda
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
Todos somos Genios
2 Respuestas
Respuesta Más Útil
Kos , "while charging with a laptop" is what will not work for you. The original charger has 15v 1.2A (18Watts). For normal charging, a charger would have to have an output at least 12v and 1.5A (18Watts). Your laptops USB port, or any other computer USB port will only provide 500mA (0.5A). Double check the "tried a different charger" values. Use a new cable as well. Since it is charging, however slow, on your laptop, I'd say your issues are most likely not with your tablet. Hope this helps, good luck.
Fue útil esta respuesta?
Calificación 1
I have had this exact same problem, and it means that the wall plug part of the charger is not working properly. That needs to be replaced. The cable is not the problem.
Calificación 0
Comentarios:
I had asimilar problem and it turned out to be the charging cable.
por
Añadir tu respuesta
Kos estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 5
Últimos 30 Días: 34
Todo El Tiempo: 4,472
