Slides/gestures after change of battery (3 GS)
Everything else wifi (jailbreak springboard on top left), music (home button voice command) seems to work. Most of the areas are unresponsive. After reboot I also can´t type all numbers.
Could be a loose connector? If yes which of them?
The iPhone is running now with WiFi, Music, Location, Buetooth to empty the battery. Then I gonna open it again.
Can I also open it while running? Will it turn off automatically or is dangerous? I just ask cause I can´t use the slide to switch function. Any other solution?
Many thanks.
Es esta una buena pregunta?
3 comentarios
Okay it was the connector. But now I can´t charge it. As soon as it´s unplugged it switches off. Any idea?
- de Quazzimodo
I tried two different chargers - doesn´t work.
- de Quazzimodo
Did you check the battery ?
- de yaniv cohen
