Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Only booting up in Darwin
Hello,
My ibook has been booting up only in Darwin(black screen looks like old DOS start up). I have used the start up disk to troubleshoot the software and an error did not surface. I followed the trouble shooting site for apple, but know one could figure out my next step. I did a hardware test ibook version 2.2.1 and the following error message came up: Memory Error detected error code 2MEM/1/4:D1MM1/J7. That was all it found. I took it to the genius bar and the print out they gave me stated "failing AHT RAM test." I dont have the extra cash to get it repaired by Apple. Could anyone help me please. I love this ibook and I want it to last a little longer until I can afford to purchase a new one.
Thank you to anyone who can help.
Samara
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
Kits para Nintendo Switch
Una solución rápida para volver al juego
Comprar kits de Switch
2 Respuestas
Solución Elegida
Remove your memory and try to boot with installed memory only. If successful you have a bad memory stick. Replace it and all should be good. Ralph
Fue útil esta respuesta?
Puntuación 1
The error you provided indicates the RAM soldered on the logic board has failed. You could try adding a
RAM module in the expansion slot, to see if the computer will use it instead of the onboard RAM.
Puntuación 1
Añadir tu respuesta
SAB estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 747
