Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3531 Ver todo
Is it normal that I charge my phone 3x a day
I have to charge my iphone 5s almost twice a day is it normal problem or do you think something is wrong with the battery? I haven't tried any restore or smth but sometimes when I want to charge my phone there is 8% and when I connect it it shows 13%. I have no warranty so please dont tell me to take it to apple.
Es esta una buena pregunta?
Puntuación 3
3 comentarios
How have you no warrenty as the iPhone is not a year old yet
- de
They cancelled it because of a broken screen
- de
Oh ok I don't think they can cancel warrenty cause of broken glass I could be wrong tho
- de
Agregar un comentario
5 Respuestas
Solución Elegida
Download and Run Coconut Battery on your Mac. It has an iOS option so you can go in and check the actual condition of your iPhone or iPad battery instead of just guessing.
http://www.coconut-flavour.com/coconutba...
Fue útil esta respuesta?
Puntuación 2
Respuesta Más Útil
It all depends on how much you use the phone, as well as other symptoms the phone is displaying. First of all, does the phone charge all the way to 100% when left plugged in? If so, look into how much you're using the phone. If you're browsing the internet and doing a lot of data heavy stuff, expect more drain. Also, if you're in a location with poor cell reception, your phone will use more battery searching for a signal. Try leaving the phone on Airplane mode for a day if you can (maybe turn it off once an hour) and see how the battery life holds up. If it's still bad you may want to look into replacing the battery.
Puntuación 2
3 comentarios:
But every 1-2 minute I get 1% down
- de
In airplane mode?
- de
first of all just take your mobile phone to mobile reparing shops cuz iphone does not have a removable battrey and then in mobile reparing shops they will take it out the battrey and check if ur battrey is bulged and if its bulged u need to replace a new battrey and if not bulged then its ur choice if u want to prolong or replace its up to u.
- de
Also for Windows users you can use 3UTools to check battery condition of iPhone and iPad batteries.
I'd say charging your phone two times a day or morning / night is normal. If the phone drains in like 4 hours of use then the battery is probably bad. Check battery condition first before considering replacing.
Update (05/22/2017)
Just check your battery health via computer using 3utools on windows or coconut battery on Mac.
Puntuación 2
If you have battery issues with the iPhone 5S, I highly recommend to try disabling the Parallax effect that was introduced in iOS 7.0
Make this change and test it for a couple days, it definitely helped me.
Settings > General > Accessibility and tap Reduce Motion to "on."
Its actually number 3 on the list of how to Stop iOS 7 From Killing Your iPhone Battery: http://mashable.com/2013/10/11/ios-7-bat...
Good Luck!
Danny.
PS Don't forget that the LCD screen being on is the biggest battery drain of all. If you are constantly with the screen lit, you should expect the battery to drain quicker than others are likely to experience.
Puntuación 1
Depending on your usage habits (ie watching Netflix all day) it could be normal, but if you just use your phone for calls/texts and occasional apps then it is most likely a battery issue.
Puntuación 0
Añadir tu respuesta
Ali Cameron estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 11,889
