Saltar al contenido principal
Modelo A1286. Lanzado en febrero de 2011 / 2.0, 2.2 o 2.3 GHz Procesador Intel Core i7 de cuatro núcleos
Preguntas 586 Ver todo
My MacBook has recently popped open now beeps-what do I do?
While working, my macbook made a popping noise, like a gunshot. Now it only beeps like a truck backing up when I start it up. The rest of functionality is completely frozen. What do I do if it is just past warranty?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Jessi Reel, the popping noise needs to be investigated properly. You will have to disassemble your MacBook, use these guides MacBook Pro 15" Unibody Early 2011 and take a good luck at the components. Check for any charred, missing or burned components. Also check your battery and make sure it is in good condition. Once you have done that, let us know what you found.
Fue útil esta respuesta?
Puntuación 1
Popping noise sounds like the battery exploded. Open the bottom cover and remove it to see if it bulges. The macbook should still boot without the battery, so you can test it.
Puntuación 0
Añadir tu respuesta
Jessi Reel estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 82
