Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
iPhone de cuarta generación. La reparación es sencilla, pero el cristal frontal y la pantalla LCD deben ser reemplazados como una unidad. GSM / 8, 16, o 32 GB de capacidad / Modelo A1332 / Blanco y Negro.
Preguntas 3290 Ver todo
Battery removal or disconnection only?
Thank you for the guide on the Iphone 4 Camera replacement (3142).
However, for some part replacements, like the camera, it is not necessary to remove the battery entirely but just to disconnect it. The battery is usually firmly glued and a lot of time is wasted and the battery may be damaged.
Thus, the guide on Camera replacement (3142) should not include the FULL guide "iPhone 4 Battery Replacement (3141)" but a shorter guide "iPhone 4 Battery disconnection (24135)" which I wrote. Unfortunately, my changes have be denied without any comment and people will continue to complain on the difficulty to unglue the battery.
Do you have any idea why the battery should be removed entirely?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
Kit de Destornilladores Manta
112 bits for every fix.
Upgrade Your Toolbox
1 Respuesta
Solución Elegida
Unplugging the battery is fine and wouldn't need to be removed for that repair but I always remove the battery anyway it's just a case of preference
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
revher estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 83
