Saltar al contenido principal
Also known as the GS70 Stealth, this 17" gaming laptop was released in summer 2013 by Micro-Star International. Identified by the model number MS-1772.
Preguntas 20 Ver todo
Can we remplace mate screen for glossy screen?
hello i got a question can i remplace my mate screen for mi msi gt70 stealth for a glossy screen? and if i can how i can do it? thank you
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
4 Respuestas
Respuesta Más Útil
Looking for the same thing, I just found a website:
https://www.laptopscreen.com/English/mod...
(I haven't bought anything from them yet, don't know if they are accountable)
Fue útil esta respuesta?
Puntuación 1
1 comentario:
I have owned two generations of GS70 - 2013 version and latest 2015 version. They have different displays.
I've found and successfully replaced both screens with glossy panels.
- de
I don't know about that but only easiest way around is to apply a crystal clear screen protector on it. It would look more glossy but not be compared to those Gorilla glass screen.
Puntuación 0
Yes GS70 screen panels has glossy versions. But note that there are several generations of GS70 and they uses totally different display connection types (parallel interface LVDS, and new serial interface eDP).
So the best way is to pull out the stock display, write down the model number, then start to search online for the corresponding glossy version.
I found the easiest and most cost effective way is simply applying a glossy screen protector. The appearance is no difference from having a real glossy panel. You need to be very careful when applying the film to not having bubbles.
http://www.amazon.com/gp/product/B00D84G...
I have tried both ways, and I will stick with the 'glossy screen protector' method.
Because the glossy panel's surface is very fragile, you need to apply a glossy protector to it anyway.
Puntuación 0
Before and after applying the 17.3" COOSKIN glossy protector. The result is STUNNING :)
Puntuación 0
Añadir tu respuesta
jorgerendon91 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,712
