Repair and troubleshooting information for the Suzuki FA50 Moped.
Preguntas 73 Ver todo
no acceleration,starts hard,need help
Bike starts hard and bogs on accelbcleaned carb,good spark etc...
Please help.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
8 Respuestas
Respuesta Más Útil
How old is the gas in the tank ?
is it ready mixed or does the oil pump work (is the oil tank full?)
if the gas is older - change it, use the ready mixed one.
Fue útil esta respuesta?
Calificación 2
I had the same problem, turns out the exhaust was plugged.
the previous owner was running with oil in oil tank AND premixed fuel creating quite a carbon deposit in the exhaust and oil. Cleaned it with a wire coat hanger and burned out the rest.
Calificación 2
Comentarios:
A clogged exhaust will make you think the motor is being choked . It actually is being choked , just from the wrong end . ;)
por
Could be that you are running super rich on your fuel/air mixture. Try leaning it out.
Calificación 1
You shoulddefinitely adjust the idle and air mixture screws if your FA50's not running well. Take a look at the carburetor diagram and make sure that the air mixture screw is 1 3/4 turns, as instructed, and that the idle screw is adjusted properly.
Honestly, I wasn't able to figure out how to set the idle to "1500 +/- 150 RPM," so I just ran the bike until warm and then adjusted the screw until it "sounded right" -- whatever sounded like it should be going at.
Also, make sure that the choke cable is completely off when running the bike, and especially while adjusting the idle / air mixture screws.
Calificación 1
you might want to check the compression. it should be between 100 to 125. if its low rebuild is in its future.
nick
Calificación 1
Comentarios:
Mine was 30 so I put a bore kit on it now I'm rebuilding the carb because it sat for 5 months
por
mine is 90... cant keep it running. does it need a bore kit?
por
Make sure your transmission oil is clean if the acceleration is bad after you adjust the mixture. You'll be amazed how much this can slow you down.
Calificación 1
Comentarios:
Clean AND the correct oil as recommended in the manual .
por
If it smells rich you may want to change the spark plugs. Easy to do and should be done before mucking around with carby mixture. If you have had bad fuel your spark plugs suffer.
Calificación 0
What is the trannys fluid? And recommend oil? Any 2 stoke oil?
Calificación 0
Añadir tu respuesta
darren estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 17
Últimos 30 Días: 105
Todo El Tiempo: 6,672
