Saltar al contenido principal
Intel Core i5 de doble núcleo a 1,8 GHz (Turbo Boost de hasta 2,8 GHz) con 3 MB de caché L3 compartida
Replacing the motherboard with 8GB RAM, can I?
Hi,
My motherboard is gone due to a spill (advice: if you spill something in the macbook, just bring it in a repair shop for cleanup, as mine lasted 6 more month but would have been OK if I had cleaned it properly).
Anyway, since I am replacing logic board and top cover anyway, I thought I might put in 2.0Ghz i7 with 8GB of RAM instead of the original 1.86Ghz and 4GB.
Are there any incompatibilities between the logic boards of the same year if I put higher end internals? Given that the logic board that I replace with is from a MacBook Air 2012 A1466 same as mine..
Any thoughts? :)
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
sviests, for as long as you stay in the same year/group you should be okay with a swap. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 4
Añadir tu respuesta
sviests estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 2,038
