Saltar al contenido principal
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
Preguntas 200 Ver todo
Touch screen gets crazy after glass assembly
Hello .I just made a full housing replacement on my samsung galaxy s2.but i have a problem with the touch screen.when i press a little bit more than usual it the touch "stucks" and start random taping.so i removed the glass again and tried to make it reviel the same problem without the glass and i couldnt!it was working perfect.when i put the glass the touch gets crazy after some taps.Whan can i do?does it need uv glue?will uv glue fix that?
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Solución Elegida
maybe that you still have the plastic on the glass. it is stuck with static so could cause phantom touches. Really basic but may be something that would cause this issue.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
well no the plastic is removed
- de
Añadir tu respuesta
Michail Pappas estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 128
