iPhone 5 camera when in use shows a blank screen
When ever I try to use the rear facing camera on the iphone 5 it shows a blank screen. To if replacing the camera would solve this problem
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
Respuesta Más Útil
First, make sure no running multiple apps and opening the camera at the same time, remove SD card or replace with a new SD card, and factory reset or reroot the device.
Then, check the back camera on Galaxy S4 and ensure its connector not loose or give the camera a few sturdy tap.
Last, if all above the solutions don’t work, you should choose a new rear camera replacement for Galaxy S4. If only the camera lens is scratched or cracked, you can clean it from inside or replace with a new camera lens glass, but make sure to perform this procedure gently, as the glass is quite delicate in nature.
(from here) though it's for back camera, i think it's also suitable with front camera. You can have a try by the steps.
Have a good luck!
Fue útil esta respuesta?
Calificación 1
Añadir tu respuesta
Kristoff Ellis estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,600
