Saltar al contenido principal
Quinta generacion de iPhone. La reparación de este dispositivo es fácil y requiere destornilladores, herramientas de hacer palanca, y paciencia. GSM/CDMA /16, 32, o 64 GB / Negro o Blanco.
Preguntas 2191 Ver todo
How to fix weak Wifi signals?
I recently fixed my iPhone and after testing everything I noticed that my Wifi barley works, even when I'm in the room with the router. I put on a leather back instead of the glass back, but even without a back, or with the glass back, the wifi is still weak. I have tried the freezer trick and reset the iPhone, but to no avail. I suspect the problem may be with the one 2.7 mm Phillips screw on the Logic Board Cover.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
In the freezer :/ your only asking for more trouble don't be listening to people that try this absolute joke..
Try and tighten the screw on the top right corner just to the left of the screen assembly screw.
If that doesn't work you might have damaged the wifi connector if you replace that and still weak wifi then it's the wifi control chip.
Screws do not affect the iPhone 4S and it's wifi your thinking of the iPhone 4 which has a different setup
Last resort try a update
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Daniel Rhen estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 872
