Saltar al contenido principal
Reparación de la mayoría de las tabletas. Debido a su pequeño tamaño y al uso frecuente de adhesivo, la reparación de tabletas suele ser más complicada que la de portátiles.
Preguntas 18937 Ver todo
How do I fix black ink infested display on Toshiba Portégé R835-P56X?
Okay so here's what happened (to my knowledge)...
Left my tablet in between my keyboard and the screen... Power napped & then a not even 3hrs later I wake up and my screen is having seizures (vertical and horizontal lines) with some black splurges. I figure someone tried to close it and applied pressure with the tablet inside. I think this is true because I believe the extraterrestrial black ink sprawling across my screen begins where the corner of my tablet was. I took off the protective guard for the display to inspect that point but it appears to be internal because the screen is not cracked. I even spritzed some windex on ye ole screen and I can still see that ink. Fortunately I'm on spring break and there are some great experts! How do I fix this without being legally robbed by Toshiba? Teach me your ways! Please! Thank you for time! ☺
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Adrian, from your very good description, it does sound like you have a broken LCD. Check this video for the disassembly. You can get a replacement at numerous places like this. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Adrian estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 6
Todo El Tiempo: 1,420
