My right earpod is not working plz help fast
suddenly it is not worrking help plz
Es esta una buena pregunta?
mohamd, you also should tried it on a different device. If it still does not work, it is possible that you have either a broken wire, a short circuit in the wiring, or a bad speaker. Jiggle the wires at the plug end with the earpod plugged in and see if you can hear sounds or a hiss. The plug is the only thing that you may be able to replace. Take a look at the teardown and see how the wiring connects. Just remember, even if you do take it apart and find a way to reattach the outer shell of the small speakers, it will never be the same. There are also no replacement parts available....Hope this helps, good luck.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 5,361
1 comentario
Might be time to buy a new set
- de Crittie
