Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Modelo A1418 / Finales de 2012 / 2.7 y 2.9 GHz Procesador Core i5 o 3.1 GHz Core i7
iMac screen has black big line after replace the HD
I remove iMac display screen and then replaced ,after that it start showing the black big line.please help me what is the cause of that?
sorry my bad English
thanks for your support
Es esta una buena pregunta?
Puntuación 4
5 comentarios
Kandala.
Good morning , today May 2015 replaced the hard drive on my iMac Model A1418 and got the same your problem .
a gray line appeared the same as yours on my screen.
I want to know after a year how you solved your problem , the damage was lcd or data cable ?
thank you very much for your reply , sorry for my bad English , I speak Spanish . thank you very much again.
- de
hello,
I have the same problem !
I hope that the screen is not broken, how did you solve the problem ? please help !
thank you
best regards
- de
Hi Kandala, how exactly did you fix this problem because I have the same issue. Thanks!
- de
@ ghiuni - He had to replace the display assembly as he had damaged it in the process of taking it off. If you review the questions searching for 'Thin Series' iMac's you'll find quite a few people have damaged theirs as well. Sorry.
- de
My late 2013 iMac now sports 2 x 21" monitors after experiencing the same issue.
Leave it to the experts to replace HDDs
- de
Agregar un comentario
3 Respuestas
Solución Elegida
Kandala, this could be caused by a bad LCD as well as a bad cable. Double check your work to make sure that all cables a properly ( and straight) connected. Also, check with an external display to see if that shows the same error. If it does, then you are having issues with the graphics processor on the logic board. Hope this helps, good luck.
Fue útil esta respuesta?
Puntuación 2
Respuesta Más Útil
I understood that this problem happens if you go inside with the plastic card along the edges more than 1 cm. I inserted the card too much (14 mm) and I touched something that broke the display.
REMEMBER: when you try to remove the display DO NOT insert the plastic card along the edges for more than 1 cm.
At the moment i do not know if i will have to replace the screen or not. This could be a bad issue...
Puntuación 5
1 comentario:
Sadly, you may have damaged the display.
- de
hi,
may i know, are you change lcd screen? or anything else?
i had same problem after change my hdd
Puntuación 0
2 comentarios:
This is a common issue when you don't use the correct tools as well as follow the guide as you can damage the display just in the process of taking it off. Here's the correct tool you need to use iMac Opening Wheel.
At this point you'll need to get a new display to replace yours [producto vinculado inexistente o deshabilitado: IF173-047]
- de
Añadir tu respuesta
Kandala estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 20
Todo El Tiempo: 5,334
