Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Quinta generacion de iPhone. La reparación de este dispositivo es fácil y requiere destornilladores, herramientas de hacer palanca, y paciencia. GSM/CDMA /16, 32, o 64 GB / Negro o Blanco.
Preguntas 3044 Ver todo
4S Music Loudspeaker does not work after Light Water Damage
Recently while I was driving, it rained heavily. Although I managed to save my phone, a little bit of water managed to get in.
After cleaning, drying and thoroughly inspecting my phone, I found out that it works fine except for:
1. The USB Connector Water indicator has turned RED
2. My Alert sounds don't work when I receive a message mail or alert. However when I go to Settings>Sounds and check out, the sounds work fine.
3. I do not have any problem with Incoming calls as I can hear my phone ringing, without any issue. I can even talk using loud speaker mode.
4. I cannot play music in loud speaker mode. When I open my control centre, the volume bar appears and disappears.
5. When I connect my headphones, I have to adjust and re-adjust the headphones end, so that I can control volume, else I am unable to control volume
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
I would first clean the acual charging port your phone thinks it's in docking mode hence the volume bars disappearing ..
If that doesn't work I would replace the dock connector and see if that sorts it
Fue útil esta respuesta?
Puntuación 2
Comentarios:
Replaced the Dock Connector. Works fine.
- de
Great til hear
- de
Añadir tu respuesta
Prarth estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 327
