Water Damage, Recover Data from SSD?
Please Help! I killed my husbands macbook air. I spilled an entire glass of water over it and while he told me not to touch it for several days while it was drying out, I could not help myself. I tried to power it up a bunch.
Needless to say, it has never powered back up and Apple Genius Bar said they can just replace it for a chunck of change, but they will absolutely not do any data recovery.
My questions is....if I can get the SSD flash drive out of it ( I have located the tools on this site to order), can someone PLEASE tell me how to get the data off of it. It holds all of our honeymoon photos which I greatly desire to save, but cannot afford a data recovery service that was suggested by Apple.
Any advice will be greatly appreciated. Thank You
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
@danj I also had an accident involving water and now your coment gives me some hope.
But I don't understand the second part of it. A OWC case seems to transform the ssd into a external drive. So why do I need to put it into a friends macbook to save my data?
por
Ah! It's all about the time frame when I wrote this.
OWC didn't have the needed case out yet (it does now) so the only way with the newest model was to swap the SSD's between a working system (the exact same model) to gain access to the files.
Today we don't need to do this as OWC has the needed case to hold the SSD so after placing the SSD from the dead system into the case you'll have no problem plugging it into any Mac system to gain access to the files.
por
Agregar un comentario
3 Respuestas
Solución Elegida
It can be put into a OWC Envoy enclosure and possibly accessed via USB onto another machine. Here's the enclosure: http://eshop.macsales.com/item/OWC/MAU3E...
Fue útil esta respuesta?
Calificación 4
Comentarios:
thank you for your suggestion. Do you believe that I would place the existing SSD flashdrive into this unit and USB it into my Imac maybe and I could atleast pull the photos? My Imac is the only other device i have that was on the same level as my husbands macbook air.
I have a very old macbook that even had a much older operating system, so that probably won't work. Thank You
por
usb to iMac should be fine.
por
Hi Donna,
I too have the same problem. Please let me know if you are able to recover your data.
Calificación 0
Comentarios:
@ Sankaran - The OWC Envoy case is the ticket here! I've saved quite a few systems SSD's that way. Just make sure you get the correct model for your system (there are four different cases!) The very newest models require still a different case, which is just not available quite yet. Then, you'll need to find a friend with the exact same mode who is willing to have you swap out the SSD in his system so you can recover the data and put his SSD back in.
por
@Sankaran - It worked like a charm. I did it all by myself and "poof"
all my files are saved. Good Luck!
por
Guys,
Could this method work for a dead iphone ssd that has not been backed up?
Calificación 0
Comentarios:
nathanhbattaglia late reply but in case you're still wondering: this method does not work for iPhones. The storage of the iPhone is practically not removable from the device. So you cannot take it out of the board and put it in an enclosure and read your data like for that MacBook Air.
There are however people who specialize in data recovery from dead iPhones (I know the subject well because we do this) and dead Android phones. They are often not the same as those reputed companies who do data recovery from hard drives because the science is very different. If you need to recover data from a dead hand held device, you have to contact such people. Most of them will accept mail-in devices too. If you still need this service, let me know your location and I can recommend someone.
por
Añadir tu respuesta
Donna estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 7
Últimos 7 Días: 95
Últimos 30 Días: 478
Todo El Tiempo: 18,842
