Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3531 Ver todo
Pregunta Cerrada
iPhone 5s Battery Voltage out put
Can some one tell me if the iphone 5s battery puts out 3.68v When it not connected to the phone. Testing to see if my iphone 5s battery is bad or good. I have 2 iphone 5s battery when connected to volt meter both says 0v. when volt meter is connected to iphone 5 battery it reads the 3.68v.
Any help would be greatly appreciated.
Es esta una buena pregunta?
Puntuación 0
2 comentarios
I need to know if the battery has a voltage output on the terminal when its not connected to the logic board.
- de
Did you solve this? I would also like to know how to check these? Which two to use when measuring?
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Taylor, see if this is what you need
Device iPhone 5 iPhone 5S iPhone 5C
Battery Size (Whr) 5.45 5.96 5.73
Battery Voltage (Nominal) 3.8 3.8 3.8
Battery Size (mAh) 1440 mAh ~1570 mAh ~1507 mAh
from here Hope this helps, good luck
Fue útil esta respuesta?
Puntuación 1
3 comentarios:
- de
Yes it does. If the battery is working, you should show voltage on the contacts.
- de
Do you have a Iphone 5s battery you could test to confirm this for me. I have 2 iphone 5s battery and both say 0v on the contact. Just hard to believe i have 2 phones with both defective batteries. Do you know if the iphone 5s will show any life when there is no battery plugged in? I know all other iphones when a battery isnt pluged in, and you plug it into the wall the apple logo loops. Does the iphone 5s do this?
- de
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 14,814
