Saltar al contenido principal
The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
Preguntas 149 Ver todo
HTC One: After reassembly no GPS-Signal
I replaced the complete Front (Display, Touch, Frame).
After reassembly I have no GPS-Signal at all.
I Really don't think so but maybe I forgot to connect a cable or something.
Does anybody know where the GPS ist located on the motherboard?
Is there a GPS-antenna and where?
Thank you so much
Thmas
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Hi,
May be you have problem with antenna connector. Disassemble it again.
Look here:
HTC One Teardown
In step 16 you can see some golden contacts.
Push them up (carefully, you can broke them).
And check back housing on the places where they make contact. I'm not shure which one is for the GPS. You must have connectors for GSM, WiFi, GPS.
Regards.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Thank You for answering my question.
I dissambled it again, including mother- and daughter-Board. I checked all contacts I saw. They looked fine but again I pushed them up. Just for sure.
But still no success, GPS isn't working :-(
Is there a possibility to check the GPS-Hardware?
Thank You very much
Regards
Thomas
- de
wifi no signal
- de
I replaced the cameras and charger port and then the GPS stopped working. I took an emergency trip to help my brother and got lost. Contacted HTC and they said it would be about a two week and $150.00 fix. Found this and fixed GPD in three minutes.
http://forum.xda-developers.com/htc-one-...
Puntuación 1
1 comentario:
Great. Noticed same.
- de
you may missed to plug back the small antena beside vibrator , i just discovered my mistake, it was left under motherboard xD
Puntuación 0
Añadir tu respuesta
Thomas Dott estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 7,275
