iPhone 5 won't boot after disassembly, is my iPhone a paperweight now?
So here's the pre-story: my mom's iPhone 5 has been having problems with the sleep/power button. It wouldn't work at all. So, figuring there might be dirt, etc. causing the problem, I pulled it apart following a guide.
I cleaned everything out, made sure I was being very careful, using all the proper tools (utilizing my brand new iFixit Pro Tech Toolkit), etc. I got everything back together, then powered the iPhone on.
The good news: the power button worked!
The (very) bad news: about 5 seconds into the boot process (showing the Apple logo), the screen dims and some text appears, as if it were booting in verbose mode. Here's the text:
[NAND] _FindFlashMediaAndKeepout:601 physical nand block offset 1
[NAND] start:356 this 0xa3148400 PROVIDER=0xa16f5e80 flashMedia=0xa16f5e80
[NAND] WMR_Start:149 Apple PPN NAND Driver, Read/Write
[NAND] WMR_Start:174 FIL_Init [OK]
[NAND] WMR_Open:371 VFL_Open [OK]
[NAND] s_cxt_boot:88 sftl: error, unclean shutdown; adopted 697 spans
[NAND] WMR_Open:420 FTL_Open [OK]
[NAND] _publishServices:642 FTL capabilities: 0x0000001
[NAND] _ppnvflGetStruct:3469 Checking borrowed blocks - count: 23 max_count: 23
[NAND] _fetchBorrowedList:881 number of borrowed blocks 16
Please help! I really hope this is fixable. From my (minimally educated) look at what I wrote above, it seems like the problem is either the unclean shutdown or physical memory. *panicking* Thank you in advance for your help!!!
Es esta una buena pregunta?
6 comentarios
Update: found Tyler Farrar's fix over here, pulled off the front facing camera connector, now she boots like a charm. I'm going to dig around some more and get back to everyone.
- de Christian
Alright, got everything fixed, for the most part! Thank you everyone for the help! :)
- de Christian
So how did you end up fixing it?
- de Laurens
Laurens, he's telling us that it was a flex problem as predicted (read my answer below). Start by isolating which flex is causing the problem by taking them all off except power and adding back one by one.
- de jessabethany
The best way to repair your troubles is opening over your iPhone,and remove your battery connection for few seconds wait a little bit and reconnect your battery and your screen afterwards and Voila!! you should be all set...Any questions my name is Barri.
- de Txomin Arambarri
Mostrar 1 comentario más
