So just to clarify, the external display DOES work and display the proper video?
If so then your GPU is likely ok. Assuming this these are the steps I would take:
__________________________________________________________________
Shine a light into the display while the Mac is powered on. If you can see images/video then your backlight is out.
Try adjusting the display brightness using the F1 & F2 keys.
If adjusting the backlight brightness has no effect then try a PRAM/NVRAM reset, holding Command+Option+P+R while powering on your Mac, releasing all of the keys after you hear it chime three times.
If the issue persists then I would attempt an SMC reset, make sure your Mac is connected to it's power adapter, hold Shift+Command+Option+Power button for about 5 seconds then release all of them together, wait a second then attempt to power on normally.
If the issue still persists then you are dealing with a hardware issue. Possibilities include a blown backlight fuse, failed inverter or failed display.
If the above test did not show any video on the internal display then I would take the following steps.
If there is still no video then I would check things at a hardware level. Removing the bottom case I would disconnect the battery then disconnect and reconnect the LVDS (video) connection at the logic board (Step 20).
If the issue still persists then this is likely a hardware failure. Likely failed components would be the display assembly and/or logic board, although I would lean more towards the display.
Hope that helps!
1 comentario
how does one remove and replace the backlight fuse on a 2010 MacBook air?
- de tskraus
