Saltar al contenido principal
Pregunta Cerrada
Is it possible to install OS X on an external hard disk?
Is is possible to install OS X as a system in an external hard disk?
If so, how?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
5 Respuestas
Respuesta Más Útil
Yes. Just hook up the external disk and start up the installation software on the DVD. Early in the process, you'll be asked to pick the hard drive onto which you're installing the program. Pick the external hard drive.
You could also clone your current hard drive onto the external drive by using Carbon Copy Cloner. As I recall, there's a box you can check if you want the clone to work as a start up drive.
NOTE: If you're planning on using the external drive to start up modern Intel Macs (instead of older Power PC Macs), be sure the drive is formatted as a GUID partition. You can check this (and repartition if necessary) using Disk Utility (which you can find in the Utilities folder in your Applications folder).
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
yes i did that, but there's no drive to choose, not even my own internal hard disk.
I don't know what can i do with it.
- de
That's strange... did you restart the computer so it starts up from the installation DVD? Usually that happens automatically when you start up the installer. You won't be asked to pick the drive until after the computer has started up from the DVD.
And is the drive already formatted to use with a Mac? Can you see it when you plug it into your computer?
- de
I finally did it already! I have migrate a newer 10.3.9 (that's what i've got) to the firewire external hard disk, since my internal HD is dead. It is about 12hrs since migration and it still works fine.
Can anyone recommned what external HD works best and stable for an OS X?
Is it better to have power supply?
thank you!
Puntuación 0
2 comentarios:
Just so I understand, you're running your computer off of the external hard drive rather than the internal hard drive? And you're planning to keep doing that for a while, so you want to know what external drive will work best for that kind of work?
- de
Yes correct! Just wondering if it is good to work with an external hd.
- de
Just my two cents...
You hit the nail on the head, the external HD must be a firewire drive, in my experience USB externals will not allow themselves to be selected.
Puntuación 0
To add to the conversation ... I added OS 10.5 system to a USB flash drive (16GB) to utilize as a startup device for maintenance and repairs on my laptop ... its a bit slow to start up, but once up, it operates almost as fast as the regular system SW installed on the computer.
Puntuación 0
1 comentario:
But is it possible to wire to a USB flash drive?
- de
I haven't tried it yet, but I think you could boot from the external DVD drive, go through the regular installation process using the USB as the destination.
Puntuación 0
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 3,097
