2.26 or 2.4 GHz / White plastic unibody enclosure
Preguntas 674 Ver todo
no audio input or out, headphone jack not working.
I have no audio. The only sound I get comes from a blutooth. Under system prefs, intel hd audio id is 0, I do not no what is wrong and any help is greatly appreciated. I have tryed resetting the pram and the smc, nothing works, there is no red light coming from the headphone jack.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Agregar un comentario
¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
Visita Nuestra Tienda
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
Todos somos Genios
1 Respuesta
Solución Elegida
The headphone jack is part of the Logic board (as you can see here). So replacing it is a big job (and costly).
I would first see if the jacks internal switch is twisted or dirty. Often one of the contacts spins around disabling the switch. Use a magnifier to look down into the hole to see if the contact is correct. Use a toothpick to move it over and/or clean the surface where the contacts touch.
If you can't fix it I would look at a USB adapter or stick with the Bluetooth headphones.
Fue útil esta respuesta?
Calificación 2
Añadir tu respuesta
michael estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 84
