Saltar al contenido principal
How to remove white marks from iPhone 5 screen?
Hello. I did it to myself because the power button was not responding well it figured out that dirt might be the problem so i decided to spray just a little bit of sonax electronic component cleaner.
After i turned the phone on like half a hour latter i was left with these white water marks on the phone.
At first the marks where bigger but became to fade like in the photo. Tried putting it on rice and everything so today i decided to open the lcd digitizer and after i removed the back cover i saw the marks of the Digitizer film.
They seem very hard to clean and i am afraid to use any products like alcohol or anything else.
Also my camera now its not focusin on macro :///
Please anyone, is there anyway to clean the Digitizer or do i have to buy a new lcd ?
Thankss
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
2 comentarios
i have same problem .. any solution ???
- de
same problem then backlight kept falling
- de
Agregar un comentario
8 Respuestas
Respuesta Más Útil
Put it face up on a warm surface. Note that it may take a few days depending on the size of the marks.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
This actually may work i put it in for about 5 minutes and it faded a little bit
- de
I think that you could try putting a new layer of the film on the unit. The film causes the backlight to diffuse evenly and the damage to it is what is causing the brighter spots on the screen. I would start with buying a broken screen assembly with the film intact and attempt to move it over to the one on your device.
Puntuación 1
2 comentarios:
But is the film replaceable. I mean can i easy remove it does it have any adhesives or how can i do it. Thankss :)
- de
did you solved this issue?
- de
The problem is the liquid is under that black film and it causing the white spots
Puntuación 1
2 comentarios:
Only solution is to remove the rear film and clean the damage but you risk breaking the lcd
- de
Can this spread?! I dropped my phone in water and after putting it in rice it works I'm just worried about whether or not this white will spread through my whole screen
- de
If you attempt to clean it be sure to use 99% alcohol so it all evaporates. I had the same issue on a 4 and this took care of it. but im not sure if the alcohol will mess with the film on the 5.
Puntuación 0
1 comentario:
I tried with 96 % Alcohol on the top right angle just a bit but it seems to leave a mark so i didnt go further :/
- de
Any solution
Puntuación 0
What you need is a new backlight (if you have solder handy)
Backlight is very easy to remove. it's only held by sticky tape around the edges.
You need to remove the tape that covers the connection to the LCD.
Use a solder to detach the backlight.
then reverse the process to attach the new one.
Dont forget to clean the back of the LCD before you put on the new backlight.
otherwise you need a new LCD assembly.
Nice and easy job ..
plus you need a new rear camera ..
basically the liquid you used had sipped through the gap on power button.
underneath that power button, is the rear camera and the LCD.
it sounds like your rear camera is now liquid damaged.
Puntuación 0
Lol It cum XD LMAO!!111!!!11!1!
Puntuación 0
it seems that solution managed to slip inside the reflector of lcd assembly and after evaporating srain marks is there in reflector and this is causing uneven reflection of backlight of lcd on display and this white spot is appearing so i suggest remove display assembly completely and submerge display assembly in 99% isopropyl cleaning solution and move display assembly back and fourth it will flush out the dried strain marks and cleanup the reflector without harming lcd display and after few minutes or 1hour max into the exposure of heat isopropyl solution will evaporates and display will work fine and marks should be gone .
Puntuación 0
Añadir tu respuesta
Blendi estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 63,119
