Saltar al contenido principal
La PlayStation 3 (o comúnmente conocida como la PS3) es la tercera consola de televisión producida por Sony Computer Entertainment, esta es la sucesora de la PlayStation 2. Fue lanzada un 11 de Noviembre de 2006.
Preguntas 781 Ver todo
Repaired yellow light of death, works shortly then shuts off
I followed all the steps recommended when replacing the thermal pads and reheating the mother board. Once reassembled it worked for about 2 hours. I then turned it off. The next day when I started playing it lasted about 5 minutes then shut off. And now basically when I turn it on, it'll turn off shortly after. Not sure if there is anything left for me to do except buy a ps4, but i'd like to fix it if possible
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
I hate to break it to you, but the time that fix will last varies on each system. A friend of mine had the same problem, so I performed a similar fix, only to have him report two weeks later that it stopped working again. I was a little more rigorous in the fix and I found that does seem to make a bigger difference, but no matter how many times you try it, the problem will never go away.
The only long term solution to this problem is to perform this once again, never turn off the system, and hope for the best. Unfortunately the longest I've heard this method lasts ranges between 3-5 months.
If you do decide to do something like this, you can try my method:
1. I prefer to set my heat gun to high and give 10 seconds to the memory and 15 seconds to the CPU and GPU.
2. Let the board sit for no less than 15 minutes to give it time to cool, and do the same process to the other side of the board at the same approximate locations.
The PS4 unfortunately does not accept any PS3 games and has a terrible selection of Local Multiplayer games so if you are like me, dishing out ~$150 for a replacement system and waiting until game developers come out with game worth playing is not that terrible. Sony did announce support of the PS3 for the next two years, so you will see new titles like destiny for the PS3.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
svensorhus estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 172
