Saltar al contenido principal
Modelo A1181: procesador Core 2 Duo de 1.83, 2, 2.1, 2.13, 2.16, 2.2 o 2.4 GHz
Preguntas 1203 Ver todo
right half of the Display is black, the rest is fine
Hey Everybody,
please help me!
I really need to work with my MacBook.
The problem is:
- the right 60% of the display stays black, the rest works perfect.
- sometimes only one stripe is black and the 40% from the left are grey instead, sometimes there are some thin lines in black, everything vertical
- external monitor and screenshots are fine
- problem came and went away once, now came back and stays like that.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Respuesta Más Útil
I think it's the ribbon cable which might have become loose. If this is the problem, you might need to open it and fix it but these ribbon cables are very fragile.
Depending on the model, you can find the instructions on how to check this here:
http://www.ifixit.com/Mac-Parts/MacBook
hope this helps.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Do you have any support for the faulty cable being the problem? I have a unresolved similar issue on a 27" iMac for a customer.
- de
Thanks for the help.
- there was nothing loose, therefore I bought a new cable, but it didn't help.
I then replaced the Display itself - now everything works fine.
The guy in the store said it could have been a transistor or something in the display.
thanks anyway
Puntuación 0
Añadir tu respuesta
derhartmann estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,739
