Saltar al contenido principal
Nokia E90 is a 3G smartphone made by Nokia and the latest model of the Communicator series.
Preguntas 4 Ver todo
front light does not come on
hi
small amount of tea has been poured on nokia E90,,it has been working after some spray repair,only the front light does not come on?
What needs to be repaired?
thanks for your help
abi shahnazi
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Agregar un comentario
Kits de Reparación de Batería de iPhone
Sólo $29.99
Buy Now
Sólo $29.99
Buy Now
1 Respuesta
Solución Elegida
Hi,
If you have problem with the light on the LCD, check first the connector between LCD and board. Because you have more power consumption through the pin for light may be you have burned, broken line. Second: you can have problem with the screen. Third: if you have problem with main board you must find LCD light line from schematic diagram.
Regards.
Fue útil esta respuesta?
Calificación 1
Añadir tu respuesta
abi estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 3
Todo El Tiempo: 340
