Saltar al contenido principal
Modelo A1237 o A1304 / 1.6, procesador 1.8, 1.86 o 2.13 GHz Core 2 Duo
Preguntas 312 Ver todo
Cannot format new HDD under 10.6?
There is a lot of discussion all over the web about it, but i couldn't find a solution yet. When i try to erase or format a brand new ATA 1.8" 80GB drive (Samsung HS082HB/A) using disk utility i get this error message "POSIX reports: The operation couldn’t be completed. Cannot allocate memory"
Under 10.5 it's similar, it only says i/o error instead. The disk seems to be named nearly randomly, things like SAISQNC or else and sometimes it shows a capaticy above 2 PB.
I think its the disk controller or the ZIF cable. Great if somebody has a different suggestion.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
3 Respuestas
Respuesta Más Útil
Try reformatting with another OS, Windows or Ubuntu. You can run a VM of Ubuntu on your mac and mount it onto the VM and use disk manager in ubuntu to do it.
Fue útil esta respuesta?
Puntuación 1
Google GParted; a free piece of live sofware you won't need to install, you just need to burn it on a regular blank cd and startup your computer from there. That should format your drive.
Puntuación 1
3 comentarios:
I tried both, yours and Gabe Chais solutions, and failed. I start to believe this is really a hardware fault. GParted is actually included in Ubuntu 10.04 but couldn't do any good. Thanks to you two anyway. ++
- de
Update: Tried GParted Live on it's own and still no luck. For a change it couldn't see a drive at all. I will have a close (ohmmetered) look at that ribbon cable. I'm pretty shure the HDD itself is fine.
- de
It turned out that the HDD itself was DOA. Bummer. But it will be exchanged
- de
Hi remacberlin,
I am looking for a source of Mac parts in Europe.
Sorry - didn't know any other way to reach you!
Puntuación 0
1 comentario:
Remacs web site is listed on his profile, www.re-mac.de
- de
Añadir tu respuesta
remacberlin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 5,402
