E82 error code on 360 S
I have a E82 error code displayed and a Red LED light at the 360 S console. What should I do to fix it ? Tks
Es esta una buena pregunta?
La versión slim de la clásica Xbox 360 con un HDD de 250 GB y Wi–Fi integrado. Repararla requiere herramientas especiales.
Ben Ho, "E82 has been a common error on the slims for some time since release, E82 error is the GPU has overheated and come unseated from the main board. Try to turn the console on without a HDD in place. The HDMI cable also may be a reason so try to use a standard AV-cable. If the console still displays the error, then you may have to reflow/reball the GPU. Also, check with MicroSoft and see if it is still covered under warranty. Hope this helps, good luck.
Comentarios:
why is the xbox360 have red rinhg of death
- de Andrecious Gamble
@andrecious32 are you asking this as a general question? You just want to know why the Xbox360 was plagued by the RROD?
- de oldturkey03
@David Garcia not sure about HHD but if you are ferring to HDD that stands for Hard Disk Drive. Here are the guides to work on your Xbox Xbox 360 S Repair
- de oldturkey03
That might be it. The problem I’m having is everytime I plug in an AV cable or a HDMI cable, the power button in front turns red@oldturkey03
- de David Garcia
Ultimas 24 horas: 6
Ultimos 7 días: 49
Ultimos 30 días: 295
Todo El Tiempo: 39,514
