Is this logic board fried post liquid spill?
My GF's sister spilled a smoothie down the back of her macbook, so I am attempting to diagnose the situation for her. It appears that some of the liquid made its way through the vents and pooled right under this spot on the logic board. It didn't short out immediately. She was able to turn it off on her own, but after letting it drain and dry, it wouldn't power on. The MagSafe also shows no lights when plugged in. There's no sign of damage anywhere other than this spot, but is this enough damage to fry the whole board?
Photo of damaged area:
Es esta una buena pregunta?
2 comentarios
Any chance you can post another image of the complete logic board to determine the exact location of the damage? It will make it easier to identify. Also, for now, I would no longer try anything else with the computer/board. You are increasing the chance of further shorting out other components. Clean the complete board with sterile water and a soft brush, then rinse it thoroughly with 90%+ isopropyl alcohol.
- de oldturkey03
Added the photo of the full board. If you can't tell, it's at the bottom, right in the middle of the photo. I've avoided "fiddling" with it, aside from removing it and a quick 97% alcohol wiped down. I'm assuming that it's toast since it's not showing any signs of life, but I'm in no way an expert! Thanks for your help though!
- de Scott McKinnon
