no water when I turn on the washer
I turned the washer on and no water was coming into the washer, what do I need to fix
Es esta una buena pregunta?
Water Inlet Valve
If the washer fills very slowly, the water pressure from the house might be too low. If the pressure is good, try cleaning the screens inside the water inlet valve hose connection ports. If those are clean replace the water inlet valve.
Low Water Pressure from House Supply
If the washer fills very slowly, the water pressure from the house might be too low. If the water inlet valve isn't leaking and there are no other symptoms this problem does not need to be corrected.
Have you ever had water to it? Is it freezing where you live?
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 304
