The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
Preguntas 593 Ver todo
My samsung won't charge, and isn't the battery's fault.
My phone was working fine, and charging fine, but when i woke up in the morning and went to check my phone the battery was at 35%. I unplugged my phone, and then plugged it back in. I waited a couple minutes and then when i checked it, it still wasn't charging. I took my battery out and put it back in after 15 min, and tried again... still nothing. So i took the battery out again and took the battery out of my cousins phone (Same exact phone,) and it still wouldn't charge. I tried plugging his phone in with my battery and it worked fine. So, what should i do? Also if i do need a repair, around how much would it cost? Thanks everyone!
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 16
Comentarios:
Yeah, mine stopped being able to charge only a few nights ago, and I have bought a replacement battery, and still nothing. I have used someone elses charger that works fine for the same model of their phone. I cleaned out some lint with a toothpick, and still nothing.
por
I just recently got a new Samsung and it won't charge and I just got a new battery for it...any suggestions?
por
My Samsung S3 suddenly stopped taking a charge. The lightening bolt was on but the battery level was decreasing! Eventually it went down to 9%. I searched online: changed chargers, changed cables, gently cleaned and blew air in the female contact, changed batteries...nothing. Then I tried charging from my laptop and its working. Great. But now what when I want to charge from the wall outlet again?
por
I kept surfing for solutions and came to this one by Jens Persson. He said ...
"Solution:
-Turn the phone off
-Remove the battery
-Wait 10 seconds
-Plug in the charger
-Insert the battery
-Turn on the phone (in my case, just held down the power key for a few seconds then it showed charging, finally!)"
Thanks Jens Persson, that solutions worked perfectly...I had already tried everything else to no avail but that method worked!
por
Thank you, Jens and Ralph. This method works a treat. Annie R.
por
Mostrar 30 comentarios más
Agregar un comentario
12 Respuestas
Solución Elegida
If you can use someone elses charger and have your phone charge the problem is that your charger is done but before you throw it out try a different cable from the charger to the phone . Cables will often break inside and quit working and still look fine on the outside. but if a cable changer brings no joy you will need to replace the charger
Fue útil esta respuesta?
Calificación 7
Comentarios:
I just had this happen to my phone this morning. Remove the battery, press the power button for 1 minute then it'll work like new!
por
cant fit charger into the usb plug can it be replaced
por
Tried it, didn't work.
por
Worked for me! Thanks!!
por
I tried the answer by Justin. I really didn't think this was going to work because I was getting no connection from the USB cable to the computer. But, I tried this and it worked! Thank you! I happen to be at a resort in Mexico on a weekend during a fierce tropical storm. I really didn't want to be without my phone.
por
Mostrar 6 comentarios más
Nah mate you know how sometimes the charger port mucks up and you need to hold the charger in a certain position for your phone to charge. It's sorta like that except you'll rarely ever find that certain position again. I have the same problem. You could try replace the charger port. Because I think that's the problem.
Calificación 3
Comentarios:
Hey! Please help me out!!
My samsung galaxy note2's battery is a year old only and the battery is perfectly fine..but since today morning my battery is getting charged really fast like in every 1 minute from 60% it's directly getting charged to 62%... what should I do???
por
Had the same problem. I read all the suggestions and this is how I fixed my Samsung s5. I dipped a toothpick in WD-40 and used it to clean all the connections in the phone's charge port. I rolled the toothpick around inside the port and I could see the dirt on the tip of the toothpick. I used 2 toothpicks and used both ends of each one to collect all the dirt in the port (my charge port cover fell off months ago so it was dirty).
This problem was also causing the phone to turn back on after I turned it off - so I fixed 2 problems with this fix.
Calificación 3
Comentarios:
the toothpick tip really got dirty, phone started charging again, will now try the WD-40 when I buy some, thanks for all these suggestions,,
por
Try as a first fix to clean the bottom of the phone uUSB socket with a needle. If compacted fuzz is present there its hard to see because it's compacted.
relevant youtube video
Best of luck
Calificación 1
Comentarios:
when cleaning the port use a toothpick as a needle or anything metal can cause damage to the port
por
hello everyone ,
i can see how this problem come to many people after a time .
first check the charger cable and power outlet
restart the phone and plug the charger for 5 min and wait
for more steps try out (SPAM REMOVED)see if this works . this worked for me .
Calificación 1
Try this, pull out charger from phone slot and blow into it sharply twice now insert charger back into phone again then press the on switch once, wait 5 min and press on switch again, it should now show it's started charging....well this worked for me.
Calificación 0
It seems like the problem is with your phone and not the battery. You may try using a compress air cannister (can air) use to clean computer keyboard and blow air into the charging port of your phone and the USB port on your charger cable. You might want to check with your cell phone provider for repair suggestions.
Calificación 0
Changing charge port is feasible but as others say the S3 problem is usually bad battery.
A dead giveaway, if you take it out and meter it instead of typical 3.5 to 3.7V you will see 3.05V, if so then no amount of reconditioning will work.
Although some folks suggested connecting it in parallel with a smaller battery then running the combination down to 2.6V and recharging, a half dozen times as sometimes this works, in my experience it does not help.
The "theory" behind this fix is that the negative electrode has got into a resistive state due to overcharging and getting it past this point reverses the damage however its normally irreversible.
Calificación 0
hi how can u get ride of spam on Samsung galaxy j1
Calificación 0
Comentarios:
My phone is a Sumsung galaxy J1 Ace, it fell today from my pocket on a concret floor facing upwards. At the time this happened the percentage power was at around 49% but then later on in the evening When the charger was low i decided to put it in the charger that I usE to chargE my phone BUT it will charge for a second and stops almost immediately.This went on until the phone wAS Completly turned off and it will Start to charge but it will never go above 0% ANY suggestions with what can be done to fix the problem it will be much appreciated thank you
por
I also having same charging problem with my SamSung A9Pro. The whole night charging only can be charged 50- 67%. i suspected , the problem causes that after i had upgraded firmware.
Anyone can give suggestion.
Calificación 0
I've had the same problem for a while. Cheapest way to fix this is to order a wireless charging pad and adapter for your phone. install the thin adapter below the back cover touching the terminals in there. put the cover back on and put it on the charging pad. Your back in business.
Calificación 0
DO not use any kind of oils
It will damage the courts when you connect it back to the charger and wd 40 attracts dust .the pourt will get more dirty
Calificación 0
Añadir tu respuesta
MrSpencer estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 97
Últimos 7 Días: 699
Últimos 30 Días: 3,398
Todo El Tiempo: 187,066
