Saltar al contenido principal
Replaced Hard Drive now refuses to read any install disk
1. Replaced 1Tb Seagate drive with the same model, it went very smoothly
2. Will not read install disc, I have tried a 10.6 and 10.7 disc. It would pull up the 10.6 disc when option was held down as a boot option, when selected would do nothing. It displays a blinking folder when no disc is present.
Is this due to the discs or the computer? (old os for example)
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Comentarios:
No, I wish it was covered by that program, I checked online and at a store....
por
Agregar un comentario
1 Respuesta
Solución Elegida
First check here to see if this problem is covered by an iMac 1TB Seagate Hard Drive Replacement Program
http://www.apple.com/support/imac-harddr...
Fue útil esta respuesta?
Calificación 1
Comentarios:
When you booted from the 10.6 Retail installation disk or the original system installation disk, did you use Disk utilities to format the drive before trying to install a system?
por
por
No I was unable to use Disk utilities, the disk would not even be recognized and begin to run.
por
Añadir tu respuesta
mbaepler estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 118
