Saltar al contenido principal
iPhone de cuarta generación. La reparación es sencilla, pero el cristal frontal y la pantalla LCD deben ser reemplazados como una unidad. GSM / 8, 16, o 32 GB de capacidad / Modelo A1332 / Blanco y Negro.
Preguntas 2375 Ver todo
Water Damage stuck on Connect to Itunes
Hi All,
My Iphone 4 is water damaged.
I did the following
1)Kept it in Rice for more than a week
Nothing happened the Phone did not turn on
2) Used 99% isopropyl Alchol and Cleaned the Logic board , all the Connections as far as I could
Now when I connect to the Power source
Connect to Itunes Logo comes up
If i remove the Power source the Phone turns off
if I try to restore it with Itunes i get 2001 error
Is the Logic board dead? what else I can do to restore the phone
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
saty, since you already cleaned it, the next thing to try is to replace the battery. A failed battery can give you that problem as well as that error code.
Fue útil esta respuesta?
Puntuación 1
Try the steps that people tried in this thread. It is an old thread, but it seems to have been solved.
https://discussions.apple.com/thread/134...
Puntuación 0
1 comentario:
i tried as said in the link still 2001 error iphone 4 cannot startup after restore
- de
Añadir tu respuesta
saty estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 5,287
