Replacing the Volume button only - Not the cable
My volume button is stuck turning the volume down. I have only found the volume cable replacement guide. How do I replace the volume button itself?
Es esta una buena pregunta?
Doesn't sound like you need a new volume button sound like you need to adjust the screws connecting it inside. Lot's of the time after replacing power flex/volume cables we have to constantly adjust the screws to make sure all function properly, if that doesn't help it probably means you need a new power/flex volume button because yours is no longer functioning properly. The volume button mainly only needs replacement if it's physically damaged.
Fue útil esta respuesta?
Awesome - I will try that. Thank you!
Is the metal housing dented or dinged at all near the button? It could be jammed because of this as well.
Hmm...there appears to be a slight ding in the metal right above the volume button where the metal casing comes into contact with the glass. Very slight. Didn't notice that before...
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 125
