Step-by-step guides for canister, robotic, and upright vacuum cleaner repair.
Preguntas 452 Ver todo
won't suck the water up out of the carpet
My hoover steam cleaner just stopped sucking the water back up out of the carpet. the return bin is empty
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 6
Comentarios:
It would be nice to see a photo of where the ball is and how to get to the hoses to check them.
I did check the intake chute and it was 90 percent clean. Checked the gasket. It looked fine.
Don't want to go any further here in my bathroom. Will take it in for service.
It is about 10 years old, but not used a lot till recently. Works good when it did work.
por
It worked correctly first time I used it but this time no water at all in dirty water bin....so that mean it is in my carpet?? What the heck! I tried the fix utube but still nothing. I may need to return this as it is not working!
por
Agregar un comentario
5 Respuestas
Solución Elegida
I would check for a break in the vacuum lines, hoses and clamps.
Fue útil esta respuesta?
Calificación 4
Comentarios:
I have a blue hoover spinscrub 50 three years old or so and mine does that unless I remove the in-tank filter.yes,it's clean.
There is a valve that the filter goes on that's supposed to close when it gets full..it closes way to early with the filter in place with barely any water in the bottom of the tank.
Works fine without it,I just have to be careful to clean the valve of debris and keep an eye on the water level.
por
what valve are you talking about
por
Mine is in the dirty tank inflow opening.its yellow. Yours may be different. Examine your dirty water tank. And all entrances to it.then look insude the tank for a float of any type .
Every machine has something tha cuts off the suction once the dirty tank is full. If its stuck from gunk it can close way to early
por
Respuesta Más Útil
Try cleaning the return canister float ball. If it is stuck in the up position the machine will not make vacuum.
Calificación 8
Comentarios:
I like this +
por
I liked both of those answers, thank you!
por
In my case, the float is not a blue ball. It’s a yellow flat sided cylinder. Looks kind of like a biscuit. It was easy to fix once I finally figured out the problem with the help of this site. I would like to see a video about this problem and solution. It would help a lot of people, apparently. The trouble shooting “tips” in the factory instructions — like other videos I’ve seen — belabor the obvious and offer “duh” “solutions” to non-problems. (My machine won’t run. Solution: Make sure it’s plugged in. Duh!) my machine, btw, is a SteamVac carpet cleaner.
por
I have the same kind the flat biscuit looking yellow so what was your problem and how did you fix it you don't say this
por
Check the gasket under the dirty water tank. If there's not a good seal/broken gasket, it won't have good suction.
Calificación 2
Check the dirty tank, the back flap that you attach the hose too. Mine flipped out when I dumped the dirty water tank, pull it up , then back down, make sure you can't pull it forward, that should do the trick.
Calificación 1
I think you should call the service center or you can go through https://bestvacuum.reviews/vacuum-under-... in twenty four hours they can provide you solution.
Calificación 0
Añadir tu respuesta
Jane Ampe estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 78
Últimos 7 Días: 642
Últimos 30 Días: 3,002
Todo El Tiempo: 54,131
