Saltar al contenido principal
Modelo A1225 / principios de 2009 / 2.66, 2.93 o procesador Core 2 Duo de 3.06 GHz
Preguntas 155 Ver todo
Core 2 Extreme QX9300 on iMac 2009 early model
Hi All,
I heard that Core 2 Extreme QX9300 doesn't work on imac 2008 (imac 8.1), How about Core 2 Extreme QX9300 in a iMac 2009 early model?
I am currently using iMac 2009 early model with Core 2 2.66 GHz (e8135) and I am planing to upgrade my CPU.
There are two CPUs (e8435 and qx9300) that I can choose. I don't really know how much differences between e8435 and e8135 (3.06 GHz and 2.66 GHz), but I believe 4 cores always better than 2 cores (qx9300 vs e8135).
Es esta una buena pregunta?
Puntuación 0
Comentarios:
Did you ever have any luck with a qx9300??
- de
Did you tried QX9300 in it?
- de
Agregar un comentario
3 Respuestas
Solución Elegida
Go with an Apple 3.06 GHz Intel "Core 2 Duo" processor (E8435), with two independent processor "cores" on a single silicon chip, a 6 MB shared level 2 cache. A used one should be about $100.00
This was offered by Apple and I know it will work.
http://www.everymac.com/systems/apple/im...
Fue útil esta respuesta?
Puntuación 1
Comentarios:
The iMac i have right now came stock with the E8435 i was just wondering if the qx9300 would work in it. Haven't found much info regarding the Early 2009 imac. Most was the 2008 model
- de
@mayer Is there a definitive way to tell what CPU you have without playing in the iMac's guts?
- de
I don't think the pin out on the motherboard will be compatible. The best you could do is get a faster Core 2 Duo, but I don't think a Quad Core processor will work on a 2009 iMac.
Puntuación 0
Socket is ok, you can do it!
Check it compatibilities
Puntuación 0
Añadir tu respuesta
Mamtily estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 2,682
