The Kenmore Elite HE3 is a washing machine by Kenmore.
Preguntas 598 Ver todo
Door makes clicking noise and won't lock or start
Washing machine makes a clicking noise when we close the door but it won't lock or start.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 4
Comentarios:
Here is the fix to your clicking locks! I fixed it, so can you! Fix it!
https://www.youtube.com/watch?v=dbb-PS5R...
por
I have a little different problem brand new Kenmore high efficiency washer dryer whenever I open the dryer door the lid on the washer clicks and locks and if it's up it will just click Kenmore says there's no way that they can talk to each other that the computers inside don't talk to each other will they definitely talk to each other
por
Who the !&&* n y did they put a lid lock on it anyways omg
por
That's an interesting problem. I would have to get the voltage checked to see if that would be causing the intermittent locking. Did they install them?
por
Agregar un comentario
4 Respuestas
Solución Elegida
Door or Lid Latch Assembly
If the washer lid or door won't lock the lock and switch assembly might be defective. This is a very common problem. The lock and switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Enter your model number to see parts for your washing machine.
Main Control Board
If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Fue útil esta respuesta?
Calificación 3
Comentarios:
I get a constant LID code. The lid lock mechanism will click when I play with the bolt. Any way to get around the lid lock?
por
When I use a small screwdriver to "lock" the lid I get a du code
por
There is a pull tab/ring located at the bottom of the door lock mechanism which can be manually pulled down in order to unlock the door.
NOTE: Disconnect the power cord from the power source before removing the access panel.
Reach up along the handle side of the door and pull down on the pull ring/tab to unlock the door. You will hear a click when pulled and then manually pull the door open. The door lock assembly will likely need to be replaced. I added the instruction in the first image below.
por
So this has gotten me by many times. Remove the lid from the top by taking out two bolts on the back. After you slide The top off you will see Pink wires on the right. They connect to the hub at the top rear. Wiggle the connections on each and make sure they are tight ( you may want to unplug it first) just wiggle not force. Make sure the door is shut and make a selection. Push start. If that didn't get it try it again. I've had to do it as many as four times but once the connectors are secure it works again. Sometimes for a few months. Sometimes a couple weeks. Hope it works for you. Don't use a hammer :)
por
Rick, I'm not going to ban hammer you. But I would like you to rethink your answer. Giggling the wire four times worked, right, and it works for a couple of weeks to a couple of months. That is what I am hearing you state. My solution would be to actually fix the problem, go in and repair the connection so that it lasts years and doesn't short out the machine and actually lasts. But that's just me, I could be wrong.
por
Mostrar 5 comentarios más
Respuesta Más Útil
I have found that aggressive cursing and swearing and lamentions and general expressions of rage and self doubt, coupled with a steady beat of spit and spiteful disgust directed toward kenmore, that soul-lacking, vacuous, dead-eyed corporation that could create such a garbage locking mechanism as this.. well, anyway, I have found that if I go express and that to the machine when my wife and kid are in another room and if all do all that and shake my fists at the machine while I work through all 7 stages of grief if I do all that..!then 63% of the time such a sequence is 100% effective. Plus I jiggle the door and latch a little. That helps.
Calificación 4
Comentarios:
Love your entertaining spin! A sense of humor helps in most situations...at least for you, 63% of the time.
por
Please join the volunteers who provide answers, you're my kind of man ;-)
por
Can't even express how much this helped me. Was literally on the verge of a break down and the washer lock got busted by my less than responsible adult in law and I had my kids blankets in there that they needed for bed and this comment made me laugh and helped me get out my anger allowing me to regroup and temporarily fix the lock with super glue. Don't know if you'll see this reply but, thank you so much.
From one stressed out momma who is now going to have to replace the lid lock. Your method was 100% effective in making me feel better
por
I replaced the lock mechanizum and it still will not start without a lot of trying it just clicks over and over.lock mech went out bought new one and now it to does exactly the same as old one ..kenmore should be held to replace these or do something better
Calificación 3
Comentarios:
Is it showing an error code?
por
The error code is "dL".
por
I get the same, F dL. I've also replaced the lock mechanism and same clicking noise then error message.
por
I have the same clicking then the same error code, so frustrating
por
I too have replaced the lock mechanism myself (a woman, using a YouTube video,) and it still does the exact same thing as the old one. Except the old one I broke with a screwdriver trying to get it to work. I unplug the machine, wait, leave the door shut while it’s unplugged so it will reset, jiggle the latch, jiggle the door, nothing works. When it decides to work, it works. Kind of $@$*!& for such an expensive machine (that’s supposed to make life “easier.”) On the latch, I can’t tell if I’m supposed to push the little plastic thingie up that sticks down from the top, or try and pry the thingie that looks like a bird beak...as it seems to be “in the way” of the door hook that it’s supposed to go into?
Alas! ...Banging to top of the door handle light but firm several times while it was clicking trying to latch resulted in the loud “click” indicating the door had latched. However...while typing this, I got another “beeping” from the laundry room after 1 minute into the cycle...went in there and now see an “F 11” error...which is totally new
por
Agreed. Humor helps more than 63% of the frustrating time!! While some want the problem fixed correctly, it seems jiggling the wires is correct in this instance and saved me money. I prefer jiggling to temporarily fix rather than spending with no repair. Thank you! Thank you!!
Calificación 0
Añadir tu respuesta
josephine estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 182
Últimos 7 Días: 1,169
Últimos 30 Días: 5,411
Todo El Tiempo: 91,929
