Saltar al contenido principal
Pregunta Cerrada
Restore Loop after logic board replaced
I replaced my logic board tonight and when I put it all back together and I booted it up, it said connect to itunes, I had to restore the phone and it keeps asking to restore the phone because it was detected in recovery mode, I triple checked every connection and i have no earthly idea whats wrong with it..
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
6 Respuestas
Respuesta Más Útil
Hey gregdudds and wolfi, I used the latest redsn0w and I used the recovery fix option and I got it out, but what I had to do was do the recovery fix, and then it went into recovery mode, and I unplugged and let the screen go blank, then I plugged my phone into the computer for about 2 seconds and unplugged it and it booted, but the home button and lock button still don't work, but I use the assistive touch and I keep the auto lock feature on none, but it kills my battery because the screen is always on.
Fue útil esta respuesta?
Puntuación 1
Op here, UPDATE
It booted and works fine, but the home and lock button are not working now, the volume/vibrate works so it's not the flex cables, and the mic, speakers and lightning port work fine, so its not any broken/torn cables.
Puntuación 0
try this, it should take it out off the loop
http://blog.firmwareumbrella.com/
Puntuación 0
hi chris, same problem here!
after replacing the power-mute-volume cable the iphone 5 went into recovery loop!
what did you do to get i out?
plz help!
Puntuación 0
After replacement of an audio button/power button, i've had the same problem.
redsn0w with unplugging after 2 seconds from reboot worked for me, but Home and Power were not responding. I still can't fix it, but have found the root of a problem:
disconnection of the battery cable from logic board without turning the device off.
Puntuación 0
For Me, This Issue Indicated A Problem With The Power/Volume Flex Cable. Nothing Looked Physically Wrong With It, But Upon Replacing It, Everything Booted Up And Resolved Perfectly. Upon Trying Other Solutions To Exit Recovery Mode, I Just Kept Getting A Loop. However, Upon Replacing This Flex Cable, It Works!
Puntuación 0
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,327
