Saltar al contenido principal
How to Replace JUST the iPhone 5 screen, not the whole LCD
heya guys!
recently cracked my screen on top..not on the useable part thank god! just enough to bug me so i figured i would go get a screen that's reasonable price.
what i ended up getting was the screen itself.not the whole LCD/Digitizer part,even tho i should have.
so I'm looking into doing the repair myself, being patient and just doing my research before i even attempt this , since my phone is still working great.
so i know how to get the screen off pretty much, its just the part after I'd like to have suggestions/tips for.
i have the screw driver set the whole works, what i dont have is the tape or glue i need, and i was wondering which glue i could use, is it possible that i could use one from a regular store, instead of buying online? any tips will help! thanks:)
Es esta una buena pregunta?
Puntuación 7
Agregar un comentario
7 Respuestas
Solución Elegida
The repair is very difficult. You will spend as much getting the tools and LOCA as you would spend on a replacement screen. Yeah the glass to replace is cheap, but you need cleaning agents to clean the frame when you remove it. You need a temp controlled heat plate/heat gun, a special wire, tons of patience, cleaning agents to clean the LCD once removed. Then LOCA and align the new glass to the LCD. Once you have that it will need to be cured in a UV box. Then you need a very strong adhesive to replace the frame.
Every step of the way the failure rate is high. Most break the frame during removal. The LCD is very likely to get damaged. And assuming you make it that far, chances are the glass will shift during curing and the LCD won't be aligned correctly. Assuming you got that down, there is also a good chance that that digitizer won't function when reassembled. This repair really should be down in a static and dust free environment. My advice is to leave this repair to the repair shops. Unless you are okay with your LCD ending up looking like this:
Fue útil esta respuesta?
Puntuación 12
Hey guys sorry I forgot to respond and let you all know how ingot on! Ended up buying a screen with everything attached and successfully replaced my cracked screen myself! It worked perfect, I did have insurance on my phone ( which didn't cover personal damage/cracks) so when my battery died on it , I ended up getting a new replacement.
Worked out great :)
Melissa
Puntuación 5
I just recently attempted to replace just the glass on my iPhone 5. I got all the tools pretty cheap, along with adhesive remover. New front glass was only $1.99 on eBay. The task is fairly simple until removing the broken glass from the LCD screen. The LCD is very fragile and finally it cracked halfway thru the process. No warning at all. Everyone I know that has attempted it has failed. Replacing it as a whole unit may cost more but it is very easily done with a high success rate.
Puntuación 4
3 comentarios:
i tried it twice and snapped the lcd both times. i found out you can use a very thin metal line. i think i have enough practice to get the glass off this time. alot of trial and error. but thats only half of it. the glue part scares me i prob end up messin that up a few time b4 gettin right. just ended up ordering the thing pre assembled.
- de
I agree. I got the LCD off fine, but now it is very ugly looking the frame is bent and it works like an iPhone 5 with a cracked screen. Works but barely worth using.
- de
Jwyre that is not accurate. Screen cost $10 including all the tools
- de
melissa, "The front glass, digitizer, and LCD are all one component, thereby increasing cost of repair." from here. So that means you will have to replace the whole front assembly. The guide for that is right here. This is of course not to say that some people haven't done it. Check on here as well as here for some approach. Just be warned that the success rate for this is very low, and the risk of destroying the LCD in the process is high. No, you can not get the glue in a regular store. I believe the glue used is of the LOCA variety. Hope this helps, good luck.
Imagen de iPhone 5
Guía
iPhone 5 Teardown
Dificultad:
Moderado
Imagen de iPhone 5 Pantalla LCD
Guía
Reemplazo de la pantalla LCD del iPhone 5.
Dificultad:
Moderado
40 minutes - 1 hour
Puntuación 1
I have started to have more luck with this repair. I have had a couple successful attempts. The most difficult part of this type of repair is definitely the glass removal. I have found that two things are very important to get right:
  1. Heating and Maintaining the amount of heat applied. This means keeping the entire thing between 160-170 degrees F. If it starts to cool the glue will become to thick to work with and the screen will break.
  2. Starting point. It is absolutely critical to get the wire flush and pressed against the glass. Otherwise it will cut the digitizer, polarizer or something.
The glue will get cut fast if you do this, but the corners of the screen on the top have been super glued or something. You have to keep it heated and be patient to cut this. If you mess it up the (+) or (-) things whatever they are will get totally messed up and it's dead in the water.
Liquid glue is a nightmare. It can get inside the LCD, between the LCD and backlight and it shows. It is a lot easier to use the OCA Film.
Puntuación 1
If there were any good advice at all... anywhere on this repair, it is this: JUST BUY the assembly, even if it's just the top glass that's broken. You are going to save yourself a TON of grief and aggravation in the long run. I tried to replace just the top glass, I got the special glue and all the stuff you need. I even worked on it in a static & dust free environment (My day job requires this type of environment) and even with all that and the 15 years experience (3 in the US Army) in the IT field that I have... it was a disaster !! It is so, so, so much easier just to put up the cash to get the complete digitizer/LCD assembly and just replace it. That's what I ended up having to do in the end anyhow, even after all the frustration of going through the aforementioned process. I don't know about you, but my time = $$$ and I wish I would have just done a complete replacement of the digitizer/LCD assembly. It took me 15 minutes TOPS to take the assembly out and then simply replace it. Now I know...
Puntuación 1
You can get the original Touch Panel Glass on line, which is cheaper than regular store. But I don't suggest you to replace the touch glass only. It is a very hard task.
Puntuación 0
1 comentario:
Be very careful about using the term OEM, for most people that implies that it is original - as in from Apple. But the people selling these will use the term OEM to describe a product that is manufactured similar to the original product. Imagine a factory in China producing these (not Foxcom either). One sales person tells you that the product is OEM, the other salesman from the same factory calls it Grade A aftermarket. As a safe rule of thumb, you can't get OEM, and if you do get an OEM product it is a refurb, not new.
- de
Añadir tu respuesta
melissa estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 56,138
