Does not power up, sleep light only blink once.
First of all, I'm from the Netherlands, so my english could be a bit off, sorry for that. ;-)
Got a MacBook Pro 13" here from a friend. He spilled lemonade on it, I got it two days after the incident, the Macbook will not power up and gave no response.
So I took it apart and cleaned everything with Isopropyl 99,7% to remove the lemonade residue (by the way it was spilled while the lid was closed, so it only got wet on the bottom side).
After completely cleaning everything making sure there were no lemonade stains anywhere, i put the macbook together again.
Now if i press the power button, fans come on for 1.5 seconds, the hard drive makes 1 very quiet startup "click" and the sleep LED blinks one time. After that the whole machine turn off again and give no sign of life. Pressing the power button again gives the same result.
Is there anybody who can help me or point me in the right direction?
What I have tried so far:
- Reset SMC
- Switched the RAM
- Booted on only battery
- Booted without battery
- Booted without HDD
Also tried booting using the power pads on the logic board. All give the same result.
So if there is anybody who can help me or point me in the right direction, please speak out! ;)
Es esta una buena pregunta?
1 comentario
more than two years late...and I am having the same problem. with battery, without battery, with HDD, without it, RAM in, RAM out, DVD , new power adapter, different AC power outlet etc. Nothing worked. Have you managed to find a way to fix your computer?
- de Andreas Friedrich Berendsen
