Wireless router released October 2007, model number is WGR614v9.
Preguntas 15 Ver todo
How can I fix a router that gives signal, but not internet?
My router will give off wireless signal, but it does not give internet access. I've tried restoring to factory settings, but that won't work either. Is there any way to fix this?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
Hi i am also facing wifi Router issue i am using Cisco CVR100W Wireless-N VPN Router as access point.
its connected on LAN Port from my switch I am not using WAN port of this router just because i am using Firewall Devices.
Router issue
1. some its SSID not found in network
2. its connected but not able to download anything
3. when i ping on my local getway its working proper but when i ping on google or WAN Network some its ping coming proper or some its going to break.
i am also change LAN Cable but not resolve.
help me ASAP help must appreciated also send me email on sawan.choubisa@gmail.com
por
I have some times fix a router that gives signal, but not internet face problems than i have used many methods but these methd does not work so not solve my problems so i will contact to <a href="https://babasupport.org/routers/verizon-...> Version Routers customer service</a>
por
Agregar un comentario
6 Respuestas
Solución Elegida
Check that is is working via Ethernet. You could be having DNS resolution problems. Depending upon your ISP you have to set your router up with the PPPoE username and password. Or, if you have been issued a static IP address by your provider, (you would need to have requested it), the static IP fields (including network mask and gateway) or clone the Mac (nothing to do with Apple Computers) address of your computer given to you by the provider must also be set in the router.
Once you can confirm connection via Ethernet you can set up your wireless network (seems like you know how to do that part).
If this Answer is helpful please remember to return and mark it Accepted.
Fue útil esta respuesta?
Calificación 1
Respuesta Más Útil
you may have netgear router stopped working problem, just because of few things,
  • Physical Connection problem
  • internet Connection problem
  • Firmware is outdated.
So these are few reasons, which may stop your netgear to serve the internet. so you need to make sure that your modem is connected from internet port of the router.
once you will connect the modem to the router, i will suggest you to reboot the router and modem and then try to access the internet.
Also, you need to make sure that you are getting internet from your modem. so you need to connect your modem from computer and try to access the internet. if you can't access the internet. i will suggest you to contact to internet service provider and ask them for help.
Calificación 2
netgear router problem can be solved - just reset the router using the reset key or log in the router using 192.168.1.0 or use the ip config and find out the default gateway and log in to the router and reset or update the firmware and for any other help visit netgear and get the latest firmware for router https://www.netgear.com/support/ and see if this helps you out
Calificación 1
i think this issue with netgear router can be fixed in just few simple steps
first reset the netgear router and restart the modem and router
after that setup the router again for setup follow Netgear Router Setup Guide
I hope that works for you thanks
Calificación 1
Hi,
Try connecting your PC with modem or router with RJ45 patch cable and try using internet to check if it works fine or same slow browsing issue. If you still face the slow browsing issue then the issue can be with your ISP and internet connect but its fine then problem in wireless configuration.
In case if connection is fine then go to your router`s wireless setup and make sure that broadcasting is b/g/n mixed mode, then check what broadcasting channel is selected starting from 1 to 11, in case of extreme start or end make in middle like 6 or 7 and in case of any middle number like 6 to 8 make it either 10 or 3. By changing the broadcasting channel shall hopefully stop any interference with other frequencies.
Good Luck
Calificación 0
Netgear N300 when I connect directly to the modem I get 175 but when I connect the router It drops to 95. Firmware up to date
Calificación 0
Añadir tu respuesta
roopnate estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 66
Últimos 7 Días: 512
Últimos 30 Días: 2,668
Todo El Tiempo: 59,976
