Broken Headphone tip stuck inside PS vita
So my headphone jack broke inside my ps vita, i have tried getting it out with a pair of pliers and small objects to no luck. should I go about opening it?
Es esta una buena pregunta?
The headphone jack is connected directly to the motherboard, and there is no way to remove it without soldering (reference: here and here)
I've read that getting a very small drill bit (#76) and applying some slight side pressure and flicking out may work.
I've also personally had limited success (read: one time) of very carefully and VERY gingerly drilling out the middle of a broken-off headphone jack with a tiny drill bit, then extracting with dentist tools. I'm not suggesting this as the BEST course of action, but it is possible. If you attempt, make sure you have a way to secure things so they don't move about when you're drilling. (A vise with soft pads perhaps) and be careful.
Cheers!
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 656
