La línea de laptops MacBook Pro fue planeada para usuarios profesionales. La línea de MacBook Pro incluye el MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17", y el MacBook Pro 17" Unibody.
Preguntas 13573 Ver todo
How to Reset Password?
How do you reset the password? note: i forgot what the password was even after the hint: " ".
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 8
Comentarios:
How can I reset Password without disk in Windows Vista <a href="http://bounethone.ciao.jp">B&T</a>
por
Agregar un comentario
5 Respuestas
Solución Elegida
Here are the instructions from Apple on resetting your password. Ralph
http://docs.info.apple.com/article.html?...
Fue útil esta respuesta?
Calificación 5
Comentarios:
por
Turn off the computer. After it is completely shut down hit the power button while holding "command s" Once all the text has loaded tip the following without the "" marks and with the spaces in mind. Also enter is just hitting enter and not typing enter.
1. "sbin/fsck -y" then hit enter
2. "sbin/mount -wu /" then hit enter
3. "cd /var/db/" then hit enter
4. "ls" then hit enter (notice this is a lowercase L)
5. "rm. ./.AppleSetupDone" then hit enter
6. "ls" then hit enter (again a lowercase L)
7. "reboot" then hit enter and wait.
When your mac starts up the next time it will be tricked into thanking its new and make you go through the info process. This will create another admin account. When you log into the account that you have just created you can go to system preferences -> accounts -> then select the account that you forgot the password to and hit change password. Then log into the previous account and delete that account that you just created and walla!!! You now have a password that works.
Calificación 3
Comentarios:
there needs to be a "/" before the sbin in the first two steps
step two, its "-uw"
por
Insert install DVD n boot from DVD.
Then use reset password
Calificación 1
I fixed it by 'Boot into Recovery Partition' method and unlocked the volume encypted with FileVault , fortunately I had saved the Filevault password. Here is the article that I followed: https://iguruservices.com/support/reset-...
They have mentioned all the steps to reset mac password for all the different version of Mac including OS X 10.4-10.5 which is simple by typing the following command :
sh /etc/rc
passwd shortusername
And to reset password in Mac OS X 10.6-10.10 use the following command in single user mode
launchctl load /System/Library/LaunchDaemons/com.apple.opendirectoryd.plist
dscl . -passwd /Users/shortusername
Also you can use recovery mode to reset mac admin password in any Mac OS X running 10.7 to 10.12
Simply by opening terminal in recovery mode and type resetpassword
Calificación 0
there are a couple of free password recovery tools that do the job .. but it takes long and is quite technical
there is a software review on this blog to unlock windows computer
http://www.digitalgrog.com.au/software/r...
but it is paid software ..i have used it ..it works
Calificación -1
Añadir tu respuesta
Bhoutik Mehta estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 16
Últimos 7 Días: 98
Últimos 30 Días: 390
Todo El Tiempo: 16,608
