Saltar al contenido principal
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
Preguntas 935 Ver todo
White Plastic around charge port is broken and iPod won't dock.
Theres a piece of white plastic that surrounds the charge port on the Ipod. Half of the plastic broke off on mine and now the speaker dock won't detect it when docked. I can still connect it to the USB cable however. Does anyone know if this white plastic piece can be replaced?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
The broken plastic is most likely what allows/forces the connection to stay just where it should be. A cable/USB cable doesn't have the same problem as it's made to fit snug at any angle.
You may need to either find a replacement casing for the ipod, or put something on the dock that it can lean onto to be pushed back to where it should be. It only needs to be a tiny amount off center to not be able to work properly.
Fue útil esta respuesta?
Puntuación 1
Blake, the plastic bezel part is available at places like this and many others. Hope this helps, good luck.
Puntuación 1
Añadir tu respuesta
Blake estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 226
