Guias de reparacion y desmontaje para una gran variedad de camaras.
Preguntas 5480 Ver todo
How to fix a lens that won't open?
Camera was dropped and fell on the spiraling\telescoping lens and seems to have jammed the mechanism. Lens won't open or close and causes the camera to auto-shutdown.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
Perhaps be specific on which type of camera you have.
por
I have this exact problem right now. Fuji Finepix S1 was dropped from a 30 cm tripod. It felt on the lens and hasn’t turned on ever since. It only shows a short text for half a second, saying it has to be turned off and on again; and then goes off inmediately. It sounds as if it's something jammed though.
por
Agregar un comentario
3 Respuestas
Respuesta Más Útil
This has happened on many Canon cameras in the past. Almost all of them I would say. There is an E18 error. If you carefully twist the camera lens, sometimes you can get it to jump a tooth on the gear mechanism that is used to open and close it. Sometimes when it is dropped it jumps the teeth on the lens and gets "over center" causing it to travel beyond it's normal range and get locked up.
Twisting it sometimes sets the round pinion gear back on the rack gear.
Other times it just breaks teeth off the gears or a shaft and you are out of luck anyway.
Also, if you send it back to Canon, they will repair it or send you a refurbished unit for a reduced price.
Check out PowerShot digital camera lens won't extend - get an E18 error for more on the subject.
And this site dealing with the E18 error.
Fue útil esta respuesta?
Calificación 2
Comentarios:
nice answer +
por
When my camera had this problem I looked for a broken model on eBay.
I found a model with a broken LCD but other wise powered on.
So I opened up both, removed the LCD from mine and put it into the eBay camera, the camera has worked for years after that.
Calificación 1
Comentarios:
Well that's more of fixing the eBay camera, not your own.
por
For point and shoot cameras, if you drop the camera while its on (lens extended) and the lens get banged, it if it won't retract, there is a good chance that its a goner, having extensive experiences with all sorts of point and shoots, if you can twist it to break it free or push it, the AF (Autofocus) system may not work as well and may not focus on anything at all. From here, you can do one of two things:
  • If its a fairly new camera, repair it, but the repair may cost just as much as the camera itself
  • or buy a new camera, because, like I said before, the repair would cost just as much as the original price.
Calificación 1
Añadir tu respuesta
artificialyte estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 22
Últimos 30 Días: 68
Todo El Tiempo: 9,357
