Inside Corner Screw Issues
Having issues getting the inner corner screws out during Display replacement of my iPhone 4. The screwdriver kit I got just doesn't seem to get a proper bite into the screws, and feels as if it's going to strip the heads. I managed to get this far very carefully without wrecking the other screws, but these corner ones are a real headache.
Are the screws in the iPhone actually traditional Phillips, or JIS? If anyone has access to both types of screwdriver, can you confirm which works best? I have #00 and #000 Phillips, and none of these feel right for the job. I have tried #00 Phillips from 3 different manufacturers, none of them seem up to the job.
Wondering if it's easier to carefully use slotted, but even 1mm seems too big for some screws; would probably need 0.8mm or smaller. Can anyone recommend where to get the best tools for the job, bearing in mind I'm in the UK?
Es esta una buena pregunta?
3 comentarios
The guide "Installing iPhone 4 Display Assembly Replacement" say that the required screwdriver are:
1-iPhone 4 5-Point Pentalobe Screwdriver
2-Phillips #000 Screwdriver
3-Phillips #00 Screwdriver.
The iPhone 4 Display Assembly (GSM/AT&T) kit has only the Phillips #00 Screwdriver, so I guess you should need only that.
Is the screw ruined?
Which one is exactly? (there are more inside corner screws, use the steps of this guide as reference)
G.
- de Giovanni
The screws are fine, but I can't get any of them to turn. Suspect the screwdrivers that I have just aren't engaging the screws. Don't want to waste money on any more unless they are going to work. Have been using the guide on here already.
- de darthvalkyr
Just solved this myself. Filed the screwdriver tip and all the blade edges down a fraction and it was able to fit the screws just well enough to get the job done. One fixed iPhone at long last :)
- de darthvalkyr
